cda said:
""""The Building Department didn't like me breaking up the restaurant into Kitchen, Business, Billiards/Arcade, and Interior Dining area. They would like me to look at the whole thing as one type of space - A3. Does this sound right?"""No that is one reason for table 1004
Not sure if this is current. Cbc
http://publicecodes.cyberregs.com/st/ca/st/b200v10/st_ca_st_b200v10_10_sec004.htm
CPC 422.1 Fixture Count. Plumbing fixtures shall be provided for the type of building occupancy and in the minimum number shown in Table 422.1 [OSHPD 1,2,3 & 4 and Table 4-2]. The total occupant load and occupancy classification shall be determined in accordance with Occupant Load Factor Table A. Occupancy classification not shown in Table 422.1 shall be considered separately by the Authority Having Jurisdiction.
The minimum number of fixtures shall be calculated at 50 percent male and 50 percent female based on the total occupant load. Where information submitted indicates a difference in distribution of the sexes such information shall be used in order to determine the number of fixtures for each
sex. Once the occupancy load and occupancy are determined, Table 422.1 shall be applied to determine the minimum number of plumbing fixtures required. Where applying the fixture ratios in Table 422.1 results in fractional numbers, such numbers shall be rounded to the next whole number. For multiple occupancies, fractional numbers shall be first summed and then rounded to the next whole number.
CPC Table 422.1, footnote 4: [bSC, DSA-AC, DSA-SS, DSA-SS/CC, HCD 1 & HCD 2, OSHPD 1, 2, 3 & 4] In accordance with Sections 1.8.7 and 301.2, the Authority Having Jurisdiction may approve alternative designs criteria when determining the minimum number of plumbing fixtures.
CPC Table A Occupant Load Factor footnotes:
* Any uses not specifically listed shall be based on similar uses listed in this table.
**For building or space with mixed occupancies, use appropriate occupancy group for each area (for example, a school may have an "A" occupancy for the gymnasium, a "B" occupancy for the office, an "E" occupancy for the classrooms, etc.)
Accessory areas may be excluded (for example: hallway, restroom, stair enclosure)
