conarb
You open up the whole can of worms related to all the building failures we've had. You can't have a dual barrier so you have to choose the side that is going to be your vapor barrier, if you paint your interior walls that decision is made for you, it has to be the interior, and if you put wall paper on walls it really has to be the interior. Our problems stemmed from sheathing sealing up the exterior, back when I started in the days before plywood 1x8 green sheathing worked because the walls breathed through the gaps and knots, with our seismic codes our engineers started requiring plywood shear walls, sealing up the exterior creating the dreaded dual barrier. At first (in the 70s) I got permission from my engineers to put the sheathing on the interior so the walls could continue to breathe out, as the engineers started requiring so much Simpson steel and red iron moment frames I recently figured out that a full red iron steel frame would be just as economical, allow me to have walls of glass (as Californians want), eliminate sheathing and the dreaded dual barrier. To touch on another of your points, even the Canadian Building scientist, Joe Lstiburek, says that you only place an interior poly vapor barrier in the coldest of climates, about 1% of the United States.View attachment 2270You especially don't want to put a poly vapor barrier in any home with air conditioning, air conditioning creates a cold interior wall and the poly becomes a condensing surface loading any hygroscopic bulk insulation with moisture rotting out even walls that can breathe to the exterior. If you have rot you have mold, if you have mold you have sick people, if you have sick people you have lawsuits. I won't even go into the chemical problems of newer building materials making people sick and lawsuits, suffice it to say that the problem is so bad that California has tripled ACH pretty much defeating any building sealing, now ASHRAE 62.2 has about tripled ACH, this is going to mandate expensive ERV and HRV systems. When our Building Standards was considering mandating fan systems to evacuate chemically laden air I wondered at the time why Panasonic was spending the millions it was to sell a few $100 fans, now I know, it wasn't $100 fans, it was $10,000 HRV or ERV systems statewide.View attachment 5453TMurray said:When reading Conard's post, I am curious where the vapour barrier layer is located within the walls. We have been using vapour barriers on the inside of buildings for years (more than three decade) and have very tight construction (I've tested houses built in the 80s that have an ach of less than 0.3 at 50Pa). I've seen walls opened up for renovations and remodels and the only places mold has been a problem is if a double vapour barrier is installed. Now, since I'm in a heating climate, the inside is the right spot for my vapour barrier.
/monthly_2010_08/572953d1939a0_amp109amp97amp112amp95amp99amp111amp110amp115amp111amp114amp116amp105amp117amp109amp46.jpg.6a5ca6c0f0535a4d556dfb5e0f334b5f.jpg
