Young Architect
As I was researching an existing building's Type of Construction. I think it is most likely a type II-B classification (I still need to do some site investigation to confirm) From photos it is steel structure with no fire proofing. If I reference the allowable sq/ft under Type II-B construction, I realized that the existing building is over what is allowed in the current code (currently around 97,000sq/ft). Is there some exception I can reference for this particular issue? I am not adding any sq/ft... I am also trying to search through IBC if there is any exception to Type II-A construction where the primary structure would not need to be 1 hour rated...
I want to add some conference rooms and a break area. The existing area is open office / private offices - not increasing the building sq/ft.
The building is equipped throughout with automatic sprinkler system. 2 stories. Currently Business occupancy and I would not change.
This building was originally built in the 1980's. I am a little perplexed how to handle this situation. I am sure there is a way to make the planned alterations without needing to add fire proofing on the existing structure. Maybe I am misunderstanding something with the fire rating requirements?
Also curious what the best way to show this information is on the code sheet of the drawing set that will be turned in for review...? Should I bring any attention to it? Or just list it as a type II-B construction with the sq/ft of the building (even though the sq/ft is over what is allowed) and call it a day?
Referencing IBC 2015
