Paul Sweet
Sawhorse
We just had a new machine room-less elevator fail inspection because it had seven 8 mm cables, instead of the three or more 9.5 mm cables required by ASME A17.1-2005 2.20.4. The specs. called for cables to be at least 10 mm, but the A/E missed that when reviewing the shop drawings.
We need to request a code modification allowing the smaller cables. Does anyone know if there are pending amendments to ASME A17.1 that allow the smaller cables, as long as there are more of them? If not, has anyone else had to request a code modification, and how did you justify the request?
