CAL GREEN - Exterior Door Protection
RANDOM
San Gabriel Valley
CAL GREEN
Section 5.407
Water Resistance & Moisture Management
5.407.2.2.1 Exterior Door Protection.
Primary exterior entries shall be covered to prevent water intrusion by using a non absorbent floor and wall finishes within at least 2 feet around and perpendicular to such opening.
Does the floor width need to span more than the actual width of the door?
For what I can tell, I would draw the door and offset a line 2 feet away in both directions (x,y)
Any feedback?
Guide to the 2013 California Green Building Standards Code (Nonresidential)
http://www.documents.dgs.ca.gov/bsc/CALGreen/CALGreen-Guide-2013-FINAL.pdf
The intent of this code provision is to minimize the amount of moisture entering the building; at the exterior entries and openings from wind-driven rain and at exterior walls from poorly designed sprinkler systems.
For entries and openings:
1. Specify nonabsorbent flooring material at the interior landing surface a minimum of 2 feet in the direction of travel and at wall finishes adjacent to the door opening on the sides and at the top. If 2 feet is not available above the opening, wall finishes may terminate at the ceiling,
2. Show compliance with one of the four listed requirements above, and
3. Install flashings integrated with a drainage plane.
Thank you Mark.
5.407.2.2.1 Exterior door protection. Primary exterior
using nonabsorbent floor and wall finishes within at least
2 feet around and perpendicular to such openings plus at
least one of the following:
1. An installed awning at least 4 feet in depth.
2. The door is protected by a roof overhang at least 4
feet in depth.
3. The door is recessed at least 4 feet.
4. Other methods which provide equivalent protection.
Live and learn, I don't pay much attention to the green code
