Calif 2010 Residential Code - Vertical distance to wood
MtnArch
San Juan Bautista, California
I've searched the forums and have come up a little empty on this.
As I read R317.1(2) I see where any wood framing members closer than 8" to grade are to be protected/preservative treated, but if you provide the protection/preservative treatment, where in the **California Residential Code** would I find the minimum separation distance no matter what? As long as I've been in the architecture business (30+ years) it's always been minimum 6" clear; I'd just like to be able to know the code section that backs it up (or says what it needs to be).
Thanks, everyone, for your help - I really enjoy the help this forum shows in (almost) every post!
Mark -
Just want to make sure about this - R317.1(2) reads:
2. All wood framing members that rest on concrete or masonry exterior foundation walls **and are less than 8 inches (203 mm) from the exposed ground.** (emphasis mine)
Is there another section where it states the separation is to be not less than 8 inches? This one seems to indicate it CAN be less as long as the wood is treated, but doesn't point to what would be the minimum.
