I wonder how much cost the added labor would bring to a typical SFR.....Yes and no,Screws, not sized per IRC butSimpson SDWS Framing screws are designed and load-rated for replacing 16d, 10d and 8d nails in framing applications. The SDWS Framing screw is 0.160" in diameter and superior to nails in holding power and pull-out resistance. It is code listed under IAPMO UES ER-192 and meets the IRC and IBC code requirements for several common wood framing applications.![]()
Strong-Drive® SDWS™ FRAMING Screw
The Strong-Drive SDWS Framing screw is a code-listed, multi-purpose structural fastener that can be used in framing applications, remodeling and interior or exterior DIY projects.www.strongtie.com
you do not need engineering, but it is an alternate method, allowed by code
That's assuming they never have to take any framing apart? Some pros may be perfect and not have to disassemble any framing, but I usually do.I wonder how much cost the added labor would bring to a typical SFR.....
I think the labor difference is where the real money is.Here is the real question?
Cost: Nail Gun vs Screw Gun?
I venture the nail gun has a distinct advantage....
That was not the Question asked, so it is not the "REAL" question, it is your question.Here is the real question?
