Michael.L
We need to build a new ADA single-occupancy restroom in a commercial space. The previous tenant build-out (~40 years old) had a small restroom for employees only; we will be demolishing this existing restroom.
But I'm curious about partition wall and ceiling requirements for commercial restrooms. I know, from poking my head above the ceiling grid that the partition walls for the existing restroom do not extend up to the roof; they terminate at 10 feet (the height of the drop ceiling). Unfortunately, I don't recall the exact construction of the ceiling inside the restroom. But I do remember seeing a standard square A/C diffuser, so it may use the same acoustic tile drop ceiling as the rest of the space.
In any case, our new restroom will be publically accessible and obviously, it must comply with current building codes. But I haven't found any building code references regarding restroom ceilings, other than required minimum height. So I'm wondering if either the ceiling must be solid (e.g., drywall construction) and/or if the partition walls must extend above the drop ceiling to the building roof.
