    Dismiss Notice
Child Daycare Restroom Facilities
Discussion in 'Accessibility' started by Papio Bldg Dept, May 6, 2011.
  1. JBI
    JBI Registered User
    Oct 17, 2009
    2,788
    288
    Just trying to help, Papio. :)
    rshuey - Yes, I did. The master bedroom was quite large and contained numerous rows of fixed seating... But I figure if the Big Guy likes an audience in His House, who am I to argue?
  2. Papio Bldg Dept
    Papio Bldg Dept Platinum Member
    Jan 24, 2011
    1,415
    2
    You have. There are pros and cons on both sides of this issue, and you have helped give me other options and viewpoints that will be helpful when this discussion occurs with the tenant and designer. Thanks again.
  3. Yangarch
    Yangarch Registered User
    May 2, 2020
    2
    0
    Sorry, this is my first time posting, and I'm having problem posting this question as an independent thread--the forum is asking to invite people? Since this thread is on a somewhat related topic, maybe it's okay to post here?
    I'm trying to figure out if there are regulations for spacing between side-by-side freestanding sinks for a daycare that I'm working on in Massachusetts. (Our state building code is based off IBC 2015). These are two sinks for children (toddlers) to wash their hands. The room also have 2 adult sinks which are accessible. I've found some guidelines for lavatory heights for different age groups, but strangely, I'm having a tough time finding out where to look for information about spacing between the sinks themselves.
    Right now, I have 2 sinks spaced 4 inches apart on a 36" wall between the end of a counter and closet.
  4. cda
    cda Sawhorse
    Oct 19, 2009
    17,965
    1,244
    welcome
    I think there is a day or two, after joining before you can free post.
    Great first question, sorry not into sinks, give it a couple of days for great answers.
  5. mark handler
    mark handler Sawhorse
    Oct 25, 2009
    10,658
    902
    Everything I see requires a 30-inch center to center clearance.
    according to growth charts a 6yr old is up to 24-inches wide
    but remember at least one needs to meet ICC A117.1. for that child using a mobility device.
    #25 mark handler, May 11, 2020
    ADAguy likes this.
  6. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,118
    1,056
    7. Where toilet facilities are primarily for children’s use, required accessible water closets, toilet compartments and lavatories shall be permitted to comply with children’s provision of ICC A117.1.
    If they are not required, they are not required to be accessible...In this particular case I believe....
  7. mark handler
    Oct 25, 2009
    10,658
    902
    But there is nothing that allows the fixtures to be closer because it is for children so by code laves shall be 30" center to center. Regardless of the bowel size or the user.
  8. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,118
    1,056
    Missed that Mark, Thanks, so this:
    405.3.1 Water closets, urinals, lavatories and bidets. A
    water closet, urinal, lavatory or bidet shall not be set closer
    than 15 inches (381 mm) from its center to any side wall,
    partition, vanity or other obstruction, or closer than 30
    inches (762 mm) center to center between adjacent fixtures.
    ADAguy and mark handler like this.
  9. ADAguy
    ADAguy Registered User
    Sep 11, 2013
    4,541
    433
    ADAAG does not apply, the operator is bound by local code, 2010 ADASAD and state licensing requirements too. Even if you are only inspecting for code.
  10. Yangarch
    May 2, 2020
    2
    0
    Thanks everyone for the input on this. I couldn't seem to find this info in our local (Massachusetts) plumbing code. So I guess the assumption is that our local codes would be based on these the ICC model codes unless they specifically note a difference.
  11. ADAguy
    Sep 11, 2013
    4,541
    433
    Considering that Mass's code (67') addressed access prior to North Carolina, this is an interesting thread you raise.
  12. steveray
    steveray Sawhorse
    Nov 25, 2009
    7,118
    1,056
    Mass. plumbing might have an ICC base sort of at this point but the plumbing board modifies the crap out of it with 100 yr old thinking....
Share This Page
