Again, do not recommend retrofitting steeple to 130MPH or the $1000 letter expense. Recommend the structural engineer specify code compliant connection/anchor for the steeple. Category 5 hurricane has greater than 150MPH winds, not an 'if': This is Florida and best is to plan for everything coming apart. Plan and then pray that steeple is not intact when detached, if intact, you no longer have a steeple but an enormous deadly missile.
Common sense, use it.
Had a similar issue on a Florida project where the covered entry roof canopy panels were intentionally designed not to meet the code required wind speed. Why? Figured better for the metal panels to blow off rather than act as a sail and uproot the whole structure intact. Still had to argue that an entire 30x30 metal canopy structure being blown across the parking lot rolling at high speed can not be envisioned better than just the metal panels blowing off. This was a safety argument resulting in a clean conscious that the possibility of 1 human life seeking refuge from the hurricane in their car does not have an additional deadly high speed rolling canopy threat.
