Moscow
Bronze Member
Have any of you been seeing the new Hercules clear primer being used? I just came from a job site were they were using the clear primer and when I took a closer look it is a primer however it only has a NSF lable not a UPC seal. I went on line to look at the product and there it was however still no approvel but NSF and it also tells you that you have to use purple primer if local plumbing code tells you that you have to. Long story short because it was all installed and under test I let it go and no leakes. Just wondering if any of you have been seeing this being used.
Thanks
Thanks
