Common path of Travel vs. Travel Distance
Oreosh8ke
In an R-2 building with 2 exits on the 4th floor:
I'm a bit confused with the code. Do we take the travel distance from the most remote point per CBC 1017.2? or is this after the Common path of travel?
Also, if per table 1006.3.2(2), Stories with one exit or access to one exit for other occupancies, how is there a common path of egress travel distance?
Any help would be helpful!
Thanks!
Thanks for your reply! That helps greatly!
For your second question::
From the wise one::
For Section 1021.2, it is because it refers to Table 1021.2, which has its own travel distance criteria. If you'll notice, the travel distance stated in the table is fairly close, if not identical, to the CPET requirements.
For Section 1015.1, the Commentary is not clear and I think it could have been worded much better. When a space that is allowed to have one exit, then CPET does not technically apply; HOWEVER, if the distance to an exit exceeds the CPET distance per Section 1015.1, Item 2, then it is no longer a space with one exit since two are now required. In reality, CPET does factor in the design of each space, even if it is only to see if the maximum distance is exceeded in order to determine if two exits need to be provided.
Also from wiser ones;
https://www.thebuildingcodeforum.com/forum/threads/common-path-of-travel.5395/
