concrete stem wall
alaskajoe
Alaska
Putting a second story on a garage with a 16" x 8" footing and 6" stem wall
2x6 wall construction. slab over footing in garage.
See table R403.1 for minimum footing width
6-inch stem wall on the 8x16 footing with garage slab resting on footing? So... the stem wall is at the side of the slab. Stem wall has a green plate attached with a studded wall supporting the garage ceiling....is that correct?
Will CJ's work for the floor of the second story or need to be changed or supported?
Pictures at 11:00?
