tbz
Silver Member
So I have a question on a where a condensate line is allowed to drain.
A little background the building is at a private outdoors club and the mechanical room is on one side of the building and 40 feet away are the 2 bathrooms & 1 slope sink.
Thus, you have a total of (3) sinks being feed off the water heater and the 2 bathroom sinks are using motion sensor faucets (Bought 2nd hand) as thus I am not even sure hot water is going to make it to them for the amount of use they will get, for this limited use building.
ITs a pole barn, so concrete floor with a metal ceiling and blown insulation.
Based on the manual the limited amount of water it will produce won't even keep a trap filled.
We are estimating 1 cup of water about every week during the winter when the building is in use and June through September maybe 2 cups in total over the 4 months.
The 5" concrete slab sits on 8 inches of gravel covering over 800 square feet minimum, and the unit has a built in neutralizer, so the water is treated.
To run it out the side of the building will ultimately freeze and we are wondering if something like this can just be core drilled through the slab and caulked?
