globe trekker
- Joined
- Oct 19, 2009
- Messages
- 1,739
Greetings to all!
I am replying to a request for information on an existing tenant space and the requirement for
separate ADA / Accessible restrooms.
I am requesting for input from the Forum to see if I am on track as a formal repsonse to the
requesting party.
Existing tenant space of approx. 2,100 sq. ft, ..Type "B" occ. group will require 2 separate
restrooms because of the calculated occ. load (Table 1004.1.1., 2006 IBC). Another Type "B"
occ. group tenant wants to move in. There is one ADA compliant restroom, and one
non-compliant restroom. Naturally, the "new" tenant does not want to spend any more than they
have to on alterations. They would like to move in and use the restrooms as they are. Section
3409.8.9, in the 2006 IBC states that where technically infeasible to comply, that one Unisex
toilet is required. In this particular application, it is technically feasible to install one additional
ADA restroom, or to enlarge both restrooms to be compliant. The existing one non-ADA
compliant restroom has clearance & maneuverability issues that would be more expensive to
make compliant than to construct a whole new ADA restroom. Section 3409.4 allows only one
Unisex that complies with Section 1109.2.1.
QUESTION # 1: Does Section 3409.8.9 "require" another ADA compliant restroom if this
particular tenant does not alter any of the existing spaces or elements, ..but rather, just
simply "move in" to the space?
QUESTION # 2: If the IBC allows an Exemption (possibly Section 3403.1), the DOJ Federal
standards would still require 2 separate ADA compliant restrooms because of the calculated
occ. load. Is this correct?
QUESTION # 3: Would an ADA compliant drinking fountain be required where there is not
one presently?
Thank you all for your input!
requesting party.
one presently?
