Considering wind uplift on posts
Lincoln
I am looking at a 234 s.f. covered porch supported along one edge that is 18 linear feet against the new addition. But then there are two large 6 x 6 posts supporting the two outside corners. Without any formal training in wind load calculations, I am guessing that the uplift on each post or column is only 1,462 lbs. But this would be even less if I can subtract the dead weight of the roof.
I am not too concerned considering how I have these two posts anchored to large concrete pier foundations. Not to mention the reaction that I received today when I showed the sketch to a structural engineer that would suggest a design that is over-done. He suggested that I could reduce a few measures.
Is it standard practice to subtract the dead weight of the roof from the force of the wind acting upward?
Thanks!
There is an ASD load combination with 0.6D + W (LRFD equivelent is 0.9D +1.6W).So, 60% of the dead load can be used to resist the wind uplift.
