For electric: UL 858 60A, gas: UL Z2121. In accordance to a 2013 study gas is not as dangerous as electric.
https://www.nfpa.org/news-and-research/publications/nfpa-journal/2013/july-august-2013/features/front-burner
"Of the two most common types of stoves, electric stoves appear to be more dangerous than open flame gas stoves. This may seem counterintuitive because an open flame seems more dangerous than a hot metal coil. But the reasons for the higher danger apparent with electric stoves include several key differences.
But in both scenarios, danger can occur when the stove is initially set on high to heat the oil, and then left unattended. (Wijayasinghe & Makey)
it appears that the oil heated on electric stoves auto-ignited more quickly than on gas stoves. The maximum heat release rate was also higher for the electric stove. This corresponds with the reasoning as to why electric stoves are more dangerous than gas stoves."
https://drum.lib.umd.edu/bitstream/handle/1903/11333/Buda_Ortins_ResearchPaper.pdf?sequence=2
There's no listing for the 3-burner gas cooktop, but the owners manual provides the following statement.
◆ Features of anti-superheating burner
◆ Automatic extinguishing safety device
•This new burner adding a temperature sensor detecting the temperature of pot, which is the most efficient safety device, can measure the temperature of the bottom of pot during cooking, reinforcing the existing safety function preventing superheating.
•Except for automatic fire-extinguishing device as well known, the burner is also equipped with anti-superheating function and fire accident preventive function, assuring your safe cooking.
Especially, a home with kids or the elderly may use it safely and conveniently.
•Overflowing soup during cooking or extinguished burner by wind may automatically stop gas supply, preventing any leakage.
◆ Pot fire prevention
◆ Take the measures as follows if the anti-superheating function starts.
•Have you ever forgot turning it off while you were heating soup? The anti-superheating burner may automatically detect overheat before a fire, shutting off gas.
◆ Oil superheating prevention
•The anti-superheating burner measures the temperature of a pot during cooking and shut off the gas before reaching the risky temperature. Especially, during frying, which is more dangerous cooking, it may shut off the gas before spontaneous combustion, preventing a fire.
※The anti-superheating burner does not cook automatically. Also, it does not prevent food burning. Anyone can make a cooking mistake and it prevents a fire accident.
There are also aftermarket devices for both electric and gas that monitor movement within a set time and smoke provides a visual and audible warning that it will shut down the appliance if it isn't reset. However it cannot control the cooking temperature.
