TheCyclist
My understanding is that occupancy classification in primarily used to determine necessary separation ratings while occupant loads are used for egress sizing and plumbing counts. The two aren't necessarily tied together, but you'd never have an assembly space, but then categorize it as storage when determining the occupant load.
Correct me if I'm wrong, but if I have a conference room within a business space and the conference room is an accessory use space, it should still be counted as an assembly space when determining the occupant load. However, would it be possible/reasonable to categorize it as business when determining the water closet count if the only intended user of the conference room are the employees of the adjacent business space? This may just depend on our local jurisdictions.
I'm also wondering if it's okay to share occupancy loads amongst water closets. For instance, if I have a large warehouse space where part will be used for manufacturing and another part will be storage, if I categorize the entire space as the higher occupant load and still fall under the more strict water closet count b/w storage & factory/industrial, could I say that a given amount of water closets would be adequate to serve both spaces even though their uses are different?
