Crushed and clogged foundation drain
atkins
Bronze Member
NH
Hello,I would need some help here as the builder claims that even though the foundation footing drains are crushed, the stones surrounding the pipe is sufficient to allow the water to flow and hence will not cause water to back up. I find this rather ludicrous but was wondering what others thought. We had water seeping upwards from the sides of the ejector tub in the basement last winter and so I decided to investigate it myself. Attached are some pictures. Does anyone know which IRC code this violates? Isn't this considered a defect for a new construction? Thanks.
/monthly_2013_10/clogged.jpg.190fd3c5065577e8bdda01163a122e51.jpg
/monthly_2013_10/clogged1.jpg.48a8fa2a0b01bdb1179345f278acdfae.jpg
/monthly_2013_10/crushed1.jpg.60b1bf4bfe84015fa6eca25c5fa0bd5e.jpg
/monthly_2013_10/crushed2.jpg.dd6af5181954050de65400b2fbf80420.jpg
In your professional opinion, the design is not satisfactory and does not comply with the intent of the code
R104.11 Alternative materials, design and methods of construction and equipment.
The provisions of this code are not intended to prevent the installation of any material or to prohibit any design or method of construction not specifically prescribed by this code, provided that any such alternative has been approved. An alternative material, design or method of construction shall be approved where the building official finds that the proposed design is satisfactory and complies with the intent of the provisions of this code, and that the material, method or work offered is, for the purpose intended, at least the equivalent of that prescribed in this code. Compliance with the specific performance-based provisions of the International Codes in lieu of specific requirements of this code shall also be permitted as an alternate.
We have this conversation quite often. If stone alone is sufficient for drainage then why is the pipe required? Stone alone will sediment up because it will cause a turbulent flow, causing suspended solids to drop out. The pipe, after the bottom gets full of sediment, will allow a laminar flow, keeping suspended solids from dropping out.
atkins,
Do you have some type of actual written contract to use / refer to ?
You may have to "lawyer up" to seek compliance, or compensation.
