It is officially deck collapse season 2025. This year starts off with the same old stories. What are your thoughts on this video?
So no plan review at all? Just issue based on the fact the knows and trusts you, or simple laziness?I just yesterday applied for a building and zoning permit for a porch (deck with roof) extension. 8 letter sized pages of drawings. Other than plot for zoning he didn't look at them and issued permit. Of course there was no ledger since it was an addition to a porch and it seems issues around ledgers are a part of a lot of these.
Life in the country. Understood. I still take issue with no plan review. We all make mistakes. If that is how the review process works, I can only assume the inspection process is not much better. Your post inspired me to write an article today.It's a rural one man 4 jurisdiction zoning and building department. I think zoning is more important to the community than building, understandbly. Property MN maintenance is not except by neighbors. And yes, it's my 4th project in 6 years, and we are pretty well acquainted. I think he's pleased I applied for a permit - many dont. We talked about decks and ledgers and piers. I'm just using PT 6x6s on gravel - but they will be UC4C treated. And he mentioned notching beams, not bolting, which was shown in my drawings. He did suggest I should have grouped all the work in one permit to save a few hundred over $50-60k worth of work over 6 or 7 years. Contrary to the tone of many posts here I do try to do my diy projects correctly, complying with codes, and hopefully good aesthetics. It sometimes feels that no one here has builders that want to comply with code, that they all want to get away with non-compliance work.
Two weeks after I completed construction, my patio roof took a direct hit from an EF2 tornado — and it held up without damage. That’s not just luck; it’s a testament to minimally reasonable design and construction by skilled guys exceeding minimum requirements. Had I replaced the roof with the old style metal and fiberglass or metal, the EF2 would have ripped it apart.Stay tuned for another exciting deck collapse near you ...
And people get upset when we ask for details instead of just issuing deck permits based on a sketch that looks like something a kindergartner might have drawn.
In the example that I provided, there were not a lot of people on the deck, and post inspection revealed code corners were cut. You can't control all loading scenarios, but you can meet the minimum standards.So I sometimes question the arbitrary and capricious assumptions often made in these failure cases. In the incident referenced, the subheadline reveals the truth — this was not a failure of construction quality, but of excessive live load, likely due to over-occupancy and possibly high-impact movement like jumping or dancing. Residential decks are not designed for uncontrolled overloading.
I much rather catch mistake in plan review than in the field. Much teeth mashing and grumblings when there is a do over.
Yesterday I stop at a job permit had not been issued yet. above ground pool deck in progress. Gently chastised the contractor for no permit in hand. Ask the contract about the gate which he was goin to put a the top of the stairway swinging in.
Long discussion about pool enclosures, requirements and proper code compliance, of course he had on one just like this in xxx town and it was fine in swinging at the top of the stairway. Explained to Mr. contractor regardless what was allowed in another jurisdiction the code does not support that type of installation.
In the end the contractor was happy I stopped by.
I remember when my boss was complaining to the engineer about the overhead rail sizing.. the engineer said it would hold a locomotive (it was for moving sides of beef from the dock to the cooler). But he wanted to make sure nobody ever could overload it. I always want to know what corners were cut, so I can try to avoid the same. As I don't like when they have the board mounted to the side of the house with no support underneath... I like overkill where I would mount a 4x4 holding up that beam...just doesn't look pretty. Like the original poster mentioned the gate that swings out (OK, now I add to my tick list, always make sure the gate swings the correct direction when for kid safety... I hate having to do rework, do it right the first time every time).In the example that I provided, there were not a lot of people on the deck, and post inspection revealed code corners were cut. You can't control all loading scenarios, but you can meet the minimum standards.
While I do agree this would help, I am going to require more people than I have to make this happen or way more expensive permit software...Funny how people want government to solve their problems and then complain when it takes too long or gets too expensive....Love to be the BO of Fantasyland....To help bridge this gap, I’d like to see cities compiling and sharing general construction examples with comments noting common reasons for inspection failures and what inspector expectations are. To assist in smooth and successful permit/construction/inspections. When you know what to expect, the relationship improves.
Yeah, but the building official for your municipality is also a follow-the-process nerd, like us.Last fall I submitted a permit application for a large new deck at my house. The next day the local building official called me to go over my beam and joist sizing. Luckily everything was right (that would have been embarrassing if wasn't).
As the provincial chief building official, I am probably the person who it makes the most sense to skip a plan review on, but he didn't.
