David Henderson
Jar would'nt be a verticle load. If done properly no load on veneer at all
One can only hope this is the type of design submittedDavid Henderson said:Jar would'nt be a verticle load. If done properly no load on veneer at all
Don't misunderstand me, some people can do it right without a seal, some people can't do it right whether they have one or not. Those who are going to do it right are probably going to be removing some bricks.jar546 said:If there is an engineered piece of equipment that is designed specifically for the application and/or approved by the ICC with a Legacy/ICC-ES report then not a problem. The engineering was already done as long as it fits the specific application. Joe Contractor telling me he is going to use a 4" x 1/4" angle iron will need an RDP.
The DTT2 typically comes as a kit with the proper bolts, etc.globe trekker said:Simpson-Strongtie DOES offer a (lateral load connector) to attach the floor joists to the deck joists, however, since most; not all, contractors do not know about these loads & requirements, someone who DOES know will need to specify all of the components needed. This lateral load connector also requires a compliant type of threaded rod, washers & nuts. http://strongtie.com/products/connectors/DTT2.asp Also, Simpson-Strongtie offers a Deck Framing Connection "GUIDE". http://www.safestronghome.com/deck/ IMO, a guide does not necessarily mean code compliant, therefore, a RDP would be required.
They do come as a kit with the hardware attached to the DTT2 in a plastic bag, threaded rod is also provided by Simpsonbrudgers said:The DTT2 typically comes as a kit with the proper bolts, etc.
You can not use that to attach a deck to brick veneer.David Henderson said:rktect1 2 of them DTT2 and a HDQ8 the DTT2 can also be used as a post and joist connector
If the AHJ can't recognize compliance, an engineer's seal doesn't make a difference.globe trekker said:Who is going to be the one to specify what is compliant for all loads, components, attachments, or approved methods since the AHJ cannot?
It probably will to an extent during depositionbrudgers said:If the AHJ can't recognize compliance, an engineer's seal doesn't make a difference.
Flashing it properly is left as an exercise for the reader.zigmark said:Brudgers- In my example the lintel was soley responsible for supporting the veneer above the deck ledger. This would allow the removal of the veneer at the ledger line and allow the ledger for the deck to be attached to the structure conventionaly with nothing bearing on the veneer and eliminating the noncompliant attachment over veneer. Seems arduaous but would be perscriptivly compliant. ZIG
Maine Deck BracketSifu said:I thought the DTT2 was a tension tie only, used for lateral bracing not gravity loads in shear. However I was at a seminar yesterday and the engineer who taught it did mention a device that installs between the structure and the deck, through the veneer, basically a stand-off device that will work in some cases. I don't know what device he was talking about and have had no time to research it. For the project in the OP I won't sign off on attachment to or through without a design.
1402.1 Would the definition of veneer be sufficient?georgia plans exam said:I should probably ask this in the commercial building section but, I'm having trouble finding an equivalent section to R703.7.3 in the 2006 IBC. Can anyone point me in the right direction?Thanks,
GPE
Yes, we have the National Building Code of Canada. Risers are not required on a deck and neither are handrails. Guards 32" high are required on on decks higher than 2' from the adjacent ground surface and when a deck exceeds 6' in hight the guards must be a minimum of 42" high. Handrails are required on stairs, but not the deck itself. Also, please don't assume Mike Holmes builds things to code as there is rarely a show that I do not see a code violation (He's a plumber by trade FYI).Pcinspector1 said:Did I just see a Holmes on Homes show last weekend where they attached a ledger to brick and drill through the ledger, brick an into the concrete foundation or did I miss something. Then I saw no deck handrail or risers on the deck. Canada has some different codes apparently?
