OK, another thread hit my hot button so I wanted to expand on it and bring it to the surface again.
The sizing of deck piers and adding a roof on it. This is a major pet peeve because I use to get grief all the time because we would reject plans based on lack of adequate footing of the existing deck and would always hear: "I've built them all over the county like that and you are the first one to deny me"
Let us dive in.
Let's say for simple math we have a 10'x10' deck attached to a house with two piers, one on each corner. A very simple setup. Break it down:
10x10=100 square feet, 50% of the load is carried by the house and the other half is split up between the two posts (assuming it is framed that way). We have to charge a 10# sq/ft for dead load plus a design load of 40# sq/ft. That sounds like 50# sq ft to me. 50lbs x 50sq' is 2500 pounds.
Without soil testing or confirmed that we are on solid rock, the code has us assume a 1500psf soil bearing capacity. Here is why I love math.
Each of the posts much be capable of supporting 1,250 pounds by design. A 12" sonotube is only 113 sq/inches so on a 1500 soil, that is only 1,170 pounds of bearing capacity. Even the DCA6 starts with an 18" sonotube or 16x16 x 7" thick footer.
My point is this. Most decks have barely enough bearing capacity to support their own design load, let alone adding a roof on it with a snow load and dead load.
Let us dive in.
