JBI
Re: deleted
My guess would be tigerloose deleted tigerloose.
Someone must have forgotten to say "please."John Drobysh said:My guess would be tigerloose deleted tigerloose.
Kil..John Drobysh said:Kil - 'I' wouldn't make it comply... 'they' will have to. It must comply with the approved plans or be redesigned.
IF a DP prepared the original plans it's going back to the DP.
IF a non-registered individual prepared them, default to prescriptive parameters OR have the non-registered individual propose a corrective measure.
Tell them how to fix it? Not me. Not my job.
I wrote Dec. 19,on page 1:Kil..If the design for the project falls under the exceptions in ORS 672.060 (Engineer's Law) [it also will fall under the exemption under ORS 671.030 - Architect's Law] - then you should require the original DP (even if the DP is an unregistered designer / person) to make the corrections and submit calculations in accordance with accepted standards. Of course, if the designer is not able to perform the calcs to support the corrective measures, you should request them to get the design and calcs prepared & stamped & signed by an RDP (licensed & registered in the state in which the project is to be built) and have it resubmitted. IOW, Oregon registered Design Professional.
Your local "laws" will triumph over the state laws and codes provide it is stricter and doesn't lessen the required laws of the state and federal level. Very simple.
It is the designer's responsibility not yours. You may make a suggestion if you clearly make a disclaimer. You have to be careful and you don't want to put liability to your employer (the local government entity). You may not be able to be sued but the city/county government itself can be sued AND you can be fired if they don't like the liability you added to them. So be careful, my friend. This is an old response..
Rick, if you would try to read (listen) before you jump to erroneous conclusions, you wouldn’t have to waste time making these unjustified threats of people losing their jobs because a non-professional designer didn’t read (listen) to what was posted. Same goes for your trying to read building codes, Oregon administrative rule and Oregon revised statues.I agree, and a lot of so called inspectors wouldn’t have a clue has to recommending options for a code complaint fix.
Yes it is.Heaven said:IBC2006 106.4 Amended Construction Documents is pretty clear.
Absolutely, we (building dept.) need to approve any changes and have the amended documents for records. If the plans were drawn by a DP, then the DP needs to make the changes. If a non-professional drew the plans than any one can make the changes, but in either case, they still need to be approved by the building dept.Work shall be installed in accordance with the approved construction documents, and any changes made during construction that are not in compliance with the approved construction documents shall be resubmitted for approval as an amended set of construction documents.
Absolutely, we (building dept.) need to approve any changes and have the amended documents for records. If the plans were drawn by a DP, then the DP needs to make the changes. If a non-professional drew the plans than any one can make the changes, but in either case, they still need to be approved by the building dept.kilitact said:IBC Section 106.4:Work shall be installed in accordance with the approved construction documents, and any changes made during construction that are not in compliance with the approved construction documents shall be resubmitted for approval as an amended set of construction documents.
