Robert
I am working on an existing bar in CA which is 2800 sq. ft, single story. The space is common to adjacent tenants and the demising walls stop several feet short of the roof structure in the attic (basically two of the attics communicate with each other). The building is Type VB construction to the best of my knowledge. At what point would we have to extend the demising walls up to the roof with proper fire rating if we are adding space to the building? I see on Table 503 (CBC) that if we were to add a second story in an A-2 occupancy, the building would have to be Type VA, and I believe trigger us to get those demising walls up to the ceiling. Our second story addition will be B occupancy and that occupancy allows Type VB construction, so not sure if that would trigger the demising walls in the rest of the bar to be extended. Thank you.
