Papio Bldg Dept
Platinum Member
I have been asked to inspect/review an existing building that is experiencing moisture issues at an exterior CMU wall that sits on a 4' AFF Cast in Place stemwall. The wall has been painted on both the exterior and interior surfaces, and shows signs that moisture is penetrating through the CMU and grout joints (i.e., bubbling and pealing paint, water streaks/staining, crumbling grout, discolouration in exposed CMU, etc.). The interior space is now being conditioned by a radiant heat system in the winter and a window box a/c during the summer and there is no interior or exterior insulation. Flashing and gutter systems at roof line appear to be in good condition and installed correctly, but I have not confirmed or tested them.
Has anyone had experience with these types of issues in CMU walls? My initial thoughts are that the moisture is not (only) passing through the wall cracks and grout lines as first suspected, but perhaps there is also a temperature differential issue which is resulting in condensation at the interior side of the wall too. I am thinking I need to create a thermal barrier for the interior before addressing the exterior issues. Any advice would be greatly appreciated.
Thanks in advance.
Thanks in advance.
