Digital thermometer?
Daddy-0-
Moderator
Powhatan, Va.
When performing your final plumbing inspection do you use a thermometer to check for 120 max for tubs etc.? I use my hand and if it feels too hot I will use a thermometer to double check. I always wonder how accurate my probed meat thermometer is ($7.00 at Target). I want to find an inspector grade digital one that will be accurate and last....so....questions.
1. How do you check temperatures on your final plumbing?
2. If you use a thermometer what kind do you have and would you recommend it?
P2708.3 Shower control valves.
Individual shower and tub/shower combination valves shall be equipped with control valves of the pressure-balance, thermostatic-mixing or combination pressure-balance/thermostatic-mixing valve types with a high limit stop in accordance with ASSE 1016 or CSA B125. The high limit stop shall be set to limit water temperature to a maximum of 120°F (49°C). In-line thermostatic valves shall not be used for compliance with this section.
It does not appear to me that resetting the water heater temp meets the code requirement. It appears that the only way to meet the code requirement would be to ensure that the water heater temperature exceeded the maximum, and that each regulated valve in the system was indeed properly equipped and adjusted to reduce the temperature to or below the limit.
Most tub/shower combos have a built in temperature limiter in the mixing valve. The problem is that some soaker tubs and jetted tubs have sink type faucets that do not limit the temp. Then you can potentially scald a child or yourself. Of course there is no temperature requirement for sinks etc. Thanks for the links and suggestions. I never thought about a laser thermometer. COOL.
We purchased the laser thermometer for checking concrete temps during cold months (yes we do go back occasionally and check temps the next day) and found out later they will work on just about everything.
Is there a limit to the distance that you can be from the concrete (or whatever you are testing)? I was thinking that one could stay in the vehicle, and test from the nice warm atmosphere of your rig while doing a drive by. That way you won't have to get out in the cold!
So they set the valve at 115 for the final inspection and crank it up to 165 (not kidding).. once you walk away. I have a $95 digital thermometer that I use at the time of final (and record the shower/tub temp on my final report). My hand is good to about 110 degrees.. then I use the thermometer. Many of my reports will reflect shower temp at 118 at final.. covers my butt.
Pressure balance is required by code here..... we did, however, have an incident where the plumber accidently connected the hot water line to the hose bibb, when the woman was hosing off her sideyard, the hose burst and doused her with scalding water.
Don't know that I'd do that Daddy... the code doesn't specify a minimum temp... just a maximum.. what they do after you leave is on the owner. Document the temperature and leave.
Good thread....I'm with Jobsaver. Really haven't checked with a thermometer but do feel with the hand to make sure hot water comes out the hot side.
1. How do you check temperatures on your final plumbing?2. If you use a thermometer what kind do you have and would you recommend it?
Daddy I do the same as you (checking the temperature through my hands after final plumbing and use a thermo if I feel that its hotter than normal. Answer to your second question- An Infra-Red Temperature Gun (its perfectly suitable for checking the temperature).
Peach,
I respectfully disagree. The code requires "hot" water for sanitation and "hot" water is defined I think as 110 deg. If I have a Final Plumbing and the water in the kitchen sink is 100 deg. I turn it down. This is usually a mistake by the contractor but sometimes they are hiding something like a forgotten TMV.
