Do sprinklers reduce required fire ratings?
Mech
Eastern PA
2000 NFPA 101
2009 IBC Chapter 34 or 2009 IEBC
Existing Health Care Facility with sprinklers
I need to re-establish a smoke barrier with either a 1/2 hour or 1 hour fire rating. Is there an exception that reduces or eliminates the required fire rating due to the fire suppression system? I skimmed the code quickly but did not find anything.
Thanks
one problem is you have to go with the stricter of the codes
what is this seperating??
A Smoke barrier by definition must be a one hour assembly where a smoke partition has no rating. The only reduction I'm seeing is for an I-3 building with a minimum of 0.1 inch thick steel in Section 710.3.
what is this separating??
Compartmentation of the building.
I just spoke with a former code reviewer and it seems that in a nursing home, the health department would not relax those rules.
I am going to suggest to the client that we pay for a preliminary review and discuss the possible options with a code reviewer before we waste too much time or money.
Thanks for the info.
CG got it.....If it needs to be a smoke barrier....Sprinklers can reduce for corridors and rated structure and some others, but nothing under 709 for SB's....
