Does a 2mX2m solar collective panel attached to the roof of a house need the design of a P.Eng.?
sunyaer
Toronto
As per Ontario building code, does a 2mX2m solar collective panel attached to the roof of a house need the design of a P.Eng.? Where is the clause of the code?
Yes. It is not a prescriptive load from Section 9.4, so an engineer would need to review the additional loading. Code section would be 9.4.1.1.(1)(c)(ii).
I am a bit going to the extreme, and just for learning purpose: sometimes, you see people anchor a big antenna on the roof of their house, is the load of these antennas a prescriptive load from section 9.4.? Does the building code deal with these situations? (I've seen there are situations where I would not do it on my house.)
In theory, any additional load needs the involvement of an engineer. However, the building official can use their own judgement on what the feel may be acceptable.
As per Ontario building code, does a 2mX2m flexible solar panels attached to the roof of a house need the design of a P.Eng.? Where is the clause of the code?
It's important to note that while a P.Eng. may not be required for the design, the installation must still comply with all relevant building codes, regulations, and electrical standards. It is advisable to consult the most recent version of the Ontario Building Code or contact your local building department or a qualified professional for accurate and up-to-date information regarding the specific requirements and regulations for solar panel installations in your area.
