Thank you for those suggestions!Consider the addition of sections of grill or perforated screen to meet the 4" requirement or maybe adding cables between support posts ( not the best idea but maybe least expensive. View what you do as an enhancement. Don't you have a reserve account?
Thank you!!As a reminder, UC Berkeley has digitized (PDF) the UBC from 1927 through 1994 - you can view them here: https://digitalassets.lib.berkeley.edu/ubc/
I would not retroactively require it, but, if replaced i would require a permit to insure it is installed to code.
The insurance company may require the upgrade in order to insure it. it is a safety issue.
The letter from Farmers Insurance was worded as a “recommendation” because it was a “building code requirement.”I would not retroactively require it, but, if replaced i would require a permit to insure it is installed to code.
There is a reserve account.I believe reserve accounts are a requirement for condos, no?
Yes. I was provided a link here with the 1979 UBC code in effect during construction and completion of this condo building, which states 9 inches.Nothing new about that code. As pointed out in other replies the IBC only goes back to 2000. The earliest copy I have is 2003 and 4 inches is the spacing given in 1012.3 for guardrail balusters.
Mark,
So if they were to add mesh to the 1979/80 fencing to protect the HOA against potential liability, that would be considered an *alteration (not repair) and therefore then be against code?Mark,
We recently had 2 projects that we were asked to look at adding those types of mesh to the existing guards with wide spacing, the issue was the frame work would not meet the loads, not to mention the new wind loads. We even looked at 3x3 squares of 1/8" wire.
Many of the older frames wont meet todays code requirement for the new loads, posts are to light and spaced to far a part. Thus when you add new product, the mesh is new, this is not a repair of the existing design, it is adding new product and is a upgrade, technically the engineers need to verify at a minimum if the frame work will hold to todays codes with the mesh added. Many fail this set of calculations.
Adding Mesh is not a repair.
So if they were to add mesh to the 1979/80 UBC code for fencing to protect the HOA against potential liability, that would be considered an *alteration (not a repair) and therefore they‘d be against current code?
Against code?So if they were to add mesh to the 1979/80 fencing to protect the HOA against potential liability, that would be considered an *alteration (not repair) and therefore then be against code?
The original construction project had a set of requirements, minimum code requirements, the original guard was designed and built to those parameters in 1979/1981. If the Guard needs repair you have to think of it as a restoration for mind thought. You are fixing it to be the same as it was when it was originally installed.So if they were to add mesh to the 1979/80 fencing to protect the HOA against potential liability, that would be considered an *alteration (not repair) and therefore then be against code?
Thank you, tbz!The original construction project had a set of requirements, minimum code requirements, the original guard was designed and built to those parameters in 1979/1981. If the Guard needs repair you have to think of it as a restoration for mind thought. You are fixing it to be the same as it was when it was originally installed.
Once you change that design or alter the guard to improve it, adding mesh, it is now an improvement, not a repair.
I am wordsmithing to make a point that the lawyers are going to make if there is an issue after the work / alteration is done.
I am not saying you can't make improvements, I actually believe your complex should look at the option of adding mesh, large openings are well documented as a safety concern with injury reports and studies.
However, don't treat it as a repair, look at it for what it is, an improvement; thus make sure what ever you do, complies with the code requirements of today because what you may think is a repair and drastic improvement, could be a major conflict with the structural section of the code for compliance. Thus creating an even bigger issue and liability.
It cost money, but an engineer will need to get involved to provide documentation that your improvement is actually a good thing, and not creating an even bigger problem.
Why do EMT's make sure to stabilize people when removing them from a accident, to make sure they don't do more damage doing something they think is helping, but is really doing more harm if there is an underlying unforeseen issue.
Hello again, tbz.First off welcome L4Gray,
Next a 24 unit Condo would not be built under the IRC. It would be built under the IBC.
Additionally, neither the IBC, nor the IRC were published prior to 2000, so if the building was built in 1981, it was built under another code.
Buildings are held to the code that was enforced based on the the permit. Codes change over time and approximately every 3-6 years and as thus you can't expect a building built in 1981 to update every portion of the building every 3-6 years to meet new building code requirements.
Hence, what ever was required at the time the permit was pulled is what you need to check and compare to what is there.
However, any new work will be required to meet the current code, not the code when built.
As to the guards and spacing, if this building is being purchased and there is funding source, the funding source and or insurance carrier may request updates to get financing or coverage.
CD's from ICC have been available in the past too.As a reminder, UC Berkeley has digitized (PDF) the UBC from 1927 through 1994 - you can view them here: https://digitalassets.lib.berkeley.edu/ubc/
Yes, thank you! The city provided me that link. 9” spacing was required according to 1979 UBC. Ours was built with 6-1/2” spacing. I just don’t know what to do next. The City said that since this is not an ADA issue, we’re under no obligation to change things. Insurance is saying otherwise CD's from ICC have been available in the past too.
Lol, for some reason a symbol came up when I entered a shrugging my shoulders emojiYes, thank you! The city provided me that link. 9” spacing was required according to 1979 UBC. Ours was built with 6-1/2” spacing. I just don’t know what to do next. The City said that since this is not an ADA issue, we’re under no obligation to change things. Insurance is saying otherwise ![]()
****! This could cost us tens of thousands. ThinkI ’ll pit the head of Glendale Ca bldg & safety against them.. take my chances.Insurance company is going to win. They will insist you reduce their liability and risk of a payout by making the guardrail to their liking. If you don’t, they will either increase your premium by a substantial amount, or they will cancel your policy.
Our HOA management co says none of their 50+ properties have received such notice.****! This could cost us tens of thousands. ThinkI ’ll pit the head of Glendale Ca bldg & safety against them.. take my chances.
This is Crazy!!
That won’t do any good. The city says you are not required to make the changes, but you are allowed to make them. The insurance company says you are required to make the changes.ThinkI ’ll pit the head of Glendale Ca bldg & safety against them.. take my chances.
City says ANY change to the railings triggers all new permits, everything related to the railings brought up to current code (including all upper walkway decks, all balcony decks, stucco, cement, etc). This could mean well over $100k, probably more like $200k. They won’t even let us put mesh against the railings without it triggering new permits. Something‘s gotta be wrong!That won’t do any good. The city says you are not required to make the changes, but you are allowed to make them. The insurance company says you are required to make the changes.
One of the biggest misconceptions on retrofitting guards is modifying older guards to comply with the 4-inch sphere without engineered supervision, and though a permit might not be needed, I always suggest going through the process of applying for one and then being told you don't need one by the AHJ; aka: the building department. If something odd happens down the road, the Monday morning oversight of being informed one was not needed, get it in writing, is simpler to explain than we didn't get one.
As to what I have seen first hand, many of the older guards built with large sphere spacing have improper structure to hold the additional weight of added infill, as they also normally have larger support post spacing combined with smaller post size than would be required with todays codes. Thus, just adding infill without complete review can be also be the undoing of a simple fix. Engineered review and plans are a must!!!!
example: In NJ on a masonry front entry porch/stoop, lets say 3 steps and a platform, normal everyday home in that area. A contractor is allowed to pull the entire top landing, treads, façade brick, even replace block work and concrete, as long as, they don't change the size or change or modify the foundation; without a permit, it is considered a repair because the foundation was not touched. However, to install new handrails/guards on the so called repaired porch/stoop we have to pull a permit. I am telling you 75% of the mass replaced and no permit required does not make sense to me.
Though a permit might not be needed, its a life safety upgrade on the property, to obtain the permit you will be required to have a complete set of engineered drawings that are stamped. The cheapest insurance policy you can get is a issued permit with a final inspection that you as the purchaser did everything properly by the book, get one IMO if they will issue it. If they wont, get a letter one was denied to be issued because it was not required.
I learned this lesson early in life and it has served me well, the building department is your friend, not your problem. It is simpler to explain why the town wouldn't issue it with paperwork, than just words. You still need all the engineer review to make certain that the retrofit is not going to cause a set of other issues. So in reality the permit is the minor cost.
Just my 2 cents
Tom
L4Gray,Our HOA management co says none of their 50+ properties have received such notice.
Crazy crazy!!
