ADAguy
Question raised: Name any and all doors covered by ADA, CBC 11b or ICC 11 that are not required to be accessible other than those with exceptions.
Yes depending on the location and function the door servesDo you have an issue with "each door" other then those specifically exempted but not on a accessible route meeting the requirements for an accessible door?
I would look at it on a case by case basisThe question is "required" not "should be" accessible doors
As we all know there is more to an accessible door than just the width. There is the latch and locking mechanisms, the approach clearances, if there is a closure or not to mention a few. All those things are not required if it is not on an accessible route. If one of those is not in compliance then you do not have an accessible door.
To paraphrase Albert Einstein
An inspector should look for what is required, and not for what he thinks should be.
I note that the OP was not asking about Ch 10 "Means of Egress", and was instead asking about accessibility.I would look at it on a case by case basis
The code does have a minimum door width And there are exceptions
1010.1.1 Size of doors and Exceptions.
He just explained that to you in his last post, in fact the local code doesn't have to align with Federal Law or ANSI, in fact that's one of the things we fight the ICC on is that it's a reflexion of totalitarian Federal law instead of being an independent agency like the ICBO and/or SBC.;Yes but, does your code align with the minimum provisions of ADASAD 2010 or only ANSI 117.1?
