Double top plate header?
Yes, this is what we found.
Guess what? It actually works, even with a 40# GSL. You see, there is going to be a deck over the top of this and it is only a 6' span. We ended up accepting this because he produced paperwork from an engineer showing that a double 2x4 on the flat works.You never know.View attachment 1935
/monthly_2013_09/IMG_3259.jpg.4c75f322ed08a73ca8e5840774722282.jpg
As long as you get the stamp.......you won't find it in the prescriptive codes. I would not have thought it so.......hmmmm, outside the box.
Probably a double 2x6? Is that the header or is the rim joist the header?
Thats a first for me, see you can teach old dogs new tricks with these fancy computer programs!
Check IECC for ceiling insulation requirements, probably going to use spray insulation I bet?
pc1
It may not. If the overhang is minimal and a 2X fascia board was used some of the loads will be transferred to the other rafters.
I doubled the versu rims on my 1st floor openings and hung the floor I-joist at the opening locations. Eliminated all headers up to a 6ft opening.
He could be doing the same thing with dimensional lumber
Many ways to skin a cat without engineering
How about a row of solid blocking over the wall....and a real header.
Appears as though the rim joist was designed to carry the load of the 3 floor joists tying into it. The "Header" looks to be nothing more than a continuation of the wall and solid backing for securing the wall cladding and door trim. Based of course on the fact that it had an engineer's approval.
