Drywall Question
pletzer28
Is green board required in a commercial building bathroom if their is no shower????
No it is not . Take a look at IBC 1210 Grounding Material.
pletzer28,
I think that Gregg meant to say "Surrounding" material
[ RE: Section 1210 in the IBC ]. :cool:
north star said:
+ + + +pletzer28,
Thank you north star, I didn't read after posting my 3 year old is sick with a fever and I ran upstairs to get his fever reducer.
Hope that your 3 yr. old is o.k.!......My prayers
are on the way.
SO i preaty much need to tile up 4 feet off of floor and rest can be normal 5/8s??
So that we can assist you better, please tell us what
code you are using!.....Thanks!
Chapt. 12 says that a smooth, hard, non-absorbent material
can be used, and that it cannot be affected by moisture.
Some have approved the use of gyp. board, in these areas,
with a laquer based, sealing type of paint, instead of the
ceramic tile [ i.e. - cheaper ].
IMO, the tile works better, and will last longer when
being cleaned on a regular basis......Your, and others
interpretations may be different.
