righter101
Gold Member
- Joined
- Dec 5, 2009
- Messages
- 604
Hello all, below is a link to a thread I started last winter. I appreciate all the feedback that was received.
http://www.inspectpa.com/forum/showthread.php?3454-Un-Heated-residential-structure
The issue that comes up, especially in our jurisdiction, is when someone is limited to a single dwelling on a parcel, they build a "bunkhouse", which, without a kitchen, doesn't meet the requirements of a dwelling, thus in compliance with zoning.
The space serves to allow for sleeping and living, just not cooking.
My previous post addressed if heat would then be required. The letter of the code indicates that it wouldn't be required. Opinions varied.
The next place I am finding this is R612.2, which states "In dwelling units...." and goes on to detail the requirements if operable windows are less than 24" above the floor and more than 6 feet above grade, the lower portion needs a guard or to be non operable.
I guess my question is this, is it reasonable, or the intent of the code to limit a life safety requirement such as this exclusively to "dwelling units", or would it be acceptable to apply to a bunkhouse, or a living/studio type use above a garage or workshop.
This brings up other questions about the definitions and interpetation of "dwelling unit". An example would be pod construction where a kitchen/living area is a separate building from the "master suite" and a separate "bedroom", communicating only with nearby paths....
We are a rural county and encounter this a lot more than an urban area would.
Thoughts.
For the code enforcement folks out there, inspectors, plans examiners, bo's, have you interpreted the dwelling unit to encompass separate buildings??
for the other side of the table folks, architects, builders, Brugers, do you see the application of this rule to other than the primairy residence as being valid.
Why or why not.
thanks for the feedback on this
Thoughts.
Why or why not.
