Looking only at the definitions, "Building Area" makes no mention of floors. So the obvious reading from my point of view is that adding a story to a building does not change the Building Area, it just changes the Floor Area. Building Area would be the footprint on the earth occupied by the building, independent of number of stories.
Interesting that you mention the term “footprint,” I was going to say something about that in my previous post. I have wondered what the proper term in the IBC is for the footprint, meaning the perimeter of the part of a multistory building that touches the ground. Even if the Chapter 2 definition of “building area” doesn’t mention the number of floors, the use in 506 supports the interpretation that it means “total area of all stories in a building” which is what you would call “floor area.”
The term “footprint” has given me some heartburn in the past. I found the term “footprint” used in two commentary documents:
1. 2018 IBC Study Companion, in a section discussing building area and referencing 503.1 and 202: “The building area is considered, in very general terms, the ‘footprint’ of the building…”
2. IBC commentary sent to me by a building official when I was asking about the concept of the building “footprint”: “A building area is the ‘footprint’ of the building; that is, the area measured within the perimeter formed by the inside surface of the exterior walls.”
My heartburn is that a footprint caused by a shoe is to the outside perimeter of the shoe, not the inside. And I think the general use of the term is to the outside of an object, such as the footprint of a piece of equipment. But in the IBC, “building area” is to the inside face of the walls, so I’d prefer that they use a term other than “footprint” to help describe the concept.
With all that said, the IBC doesn’t seem to care specifically about the building footprint (area of the ground covered by the building,) only the building area (total inside perimeter area of all floors of the building) and gross floor area as it applies to occupant load. Ground contact footprint of a building would be of interest to matters related to lot coverage for things such as zoning and stormwater control.
Since the word "floor" does not appear in the definition of "Building Area", I have to say that is inconsistent with the definitions.
I would agree with that, I’d like to see the definition of “building area” refined.
However, all of this is sounding like Building Area and Gross Floor Area are supposed to be almost the same, with the difference relating to whether the thickness of the exterior walls is included. In which case if that is the usage in the IBC, then "Building Area" should be updated to include a reference to floor area to make that clear.
No, they are the same in that regard, neither “building area” nor “gross floor area” include the exterior walls based on the commentaries. One of the refinements I’d make to the definition of “building area” is to say that it is taken to the inside perimeter of the exterior walls. In fact, I think I’d go so far as to say the definition of “building area” could be the same as for “gross floor area.” So they describe the same thing, but they use two different terms depending on what we’re doing:
1. “Building area” for 506. This makes sure that the entire building is within allowable constraints dictated by occupancy, construction type, and use of sprinklers.
2. “Gross floor area” for 1004. They use this term when determining the occupant loads for some of the functions of smaller areas within the “building area.”
