wwhitney
Well, from my point of view, the usage in 506 can't change the definition. And the definition indicates "building area" does not count multiple floors, so the usage in 506 is just sloppy. 506 appears to incorrectly conflate building area and floor area. I briefly skimmed the uses of the actual phrase "building area" in 506 and I don't think any of them are critical, in that all the actual enforceable requirements can be traced to a different term.Even if the Chapter 2 definition of “building area” doesn’t mention the number of floors, the use in 506 supports the interpretation that it means “total area of all stories in a building” which is what you would call “floor area.”
Of course, that raises the question if any section of the IBC is using "building area" according to the definition. If not, might as well change the definition if that's more convenient than changing Chapter 5.
I don't think I agree. In the definition of "floor area, gross" we have the language "The floor area within the inside perimeter of the exterior walls . . ." which explicitly excludes the "footprint" of the walls themselves. Whereas "area, building" says "the area included within surrounding exterior walls . . ." So in contrast to "floor area, gross," by not explicitly referencing the "inside perimeter", I read the "area, building" as including the footprint of the exterior walls. Which makes sense, as it includes the footprint of the eaves as well (the OP in this thread).But in the IBC, “building area” is to the inside face of the walls
OK, but as an outsider I reject the idea that a commentary can overrule the plain meaning of the definitions themselves. The internal contrast between the wording of "area, building" and "floor area, gross" carries greater weight, in my opinion, than any external commentary.No, they are the same in that regard, neither “building area” nor “gross floor area” include the exterior walls based on the commentaries.
The commentary is useful, though, to understand the intention, and so if the commentary and the usage conflict with the language of the definition, then the easiest fix is to change the definition.
Your comments about "building area" appearing primarily (exclusively?) in 506, and "gross floor area" appearing primarily (exclusively?) in 1004 make me wonder whether those two sections of the IBC come from different progenitor codes, that each had different definitions, and whether those sets of definitions were just merged without any attempt to reconcile them with each other into a coherent whole. Because it certainly doesn't seem coherent to me.
Cheers, Wayne
