Francis Vineyard
Assuming the equipment in question is 1200 amp or more with a 3 ft. wide door.
What the code says is there can be a single entrance provided that there is an unobstructed way of exit travel. My spin on this if opening the panel or door obstructs the path to the entrance (access) then another exit is required. The entrance or access to the room is not necessarily the exit. Otherwise on both sides of the equipment you need clear access or an entrance (exit).
As Gregg said the second exception is there is at least 6 ft. of clearance in front and the entrance (exit) is at least 3 ft. away, hence a 3 ft. clear path around the door.
To install equipment with a door in the manner previously described goes against the grain of safe design.
Francis
It's confusing to try and explain NFPA with ICC terminology.
Francis
