indyarchyguy
Working on a project involving side by side 11 story buildings of Type IA construction with full sprinkler. The tenant on second floor (building on the left) is expanding to adjacent building via a sky bridge. The tenant wants to have a main entry door off the main corridor from the elevators. The space itself is an A-3 occupancy due to the tenant training room needs. A 1-hour wall assembly has been constructed between the A-3 and the existing B-Occupancy that has not been built-out. We have offered the egress through the bridge connector towards the building on the left via a 1-hour rated door/wall assembly. A second fire egress door has been provided via extended corridor in order to provide the required distance between two means of egress. Fire egress signage has been provided.
I have been informed while we meet the requirements of the code, that because the main entry door is near the egress door leading down the corridor, it is too close and they are indicating this does not meet code...even though we have provided the distance and required separation between the occupancies. Any thoughts? This is in Indiana where we use the 2014 Indiana Building Code (2012 IBC with amendments). Your thoughts are appreciated. Thank you.
