bgalan26
I'm reviewing a mutli-family building with one level of subterranean parking. The architect has one of the exits coming out the rear of the subterranean level up onto a rear courtyard. The opening for the stairway is parallel to a lot line. Is there any requirements in the building code requiring this stair to be enclosed? Section 1009.3, exception 1 reads "in other than Group I-2 and I-3, exit access stairways that serve, or atmospherically communicate between, only two stories are not required to be enclosed". But this stair opens directly to the exterior near a lot line. Would the code mandate an enclosure for such a situation?
The exit is far away from the residential portion where no protection is required to the apartment building.
Thank you!
Thank you!
