I think Mark has the right idea with this picture. "2009 IRC, definitions. Mezzanine, Loft. An intermediate level or levels between the floor and ceiling of any story with an aggregate floor area of not more than one-third of the area of the room or space in which the level or levels, are located." It is NOT a bedroom and does not require separate emergency egress. Uncle Bobmark handler said:Loft?...
Since there are no walls, it would be arbitrary to say where the bedroom ends. I can't see how this could be tested in court. I could argue that the stairs down to the main level and a passage large enough to travel to the front door is all part of the bedroom, complying with the requirements for the window. Unless you have an established procedure you need to tread carefully as the decision rendered in this case will become precedent, so some thought to future situations might be in order.9.7.1.2.Bedroom Windows1)Except where the suite is sprinklered, each bedroom or combination bedroom shall have at least one outside window or exterior door openable from the inside without the use of keys, tools or special knowledge and without the removal of sashes or hardware. (See Article 9.5.1.2. and Appendix A.)
2)The window referred to in Sentence (1) shall
a) provide an unobstructed opening of not less than 0.35 m2 in area with no dimension less than 380 mm, and
b) maintain the required opening during an emergency without the need for additional support.
Same that happens in a motel 6, run faster out the front doorglobe trekker said:Say you have only the compliant egress door from this small cabin, with someone sleeping in theupstairs loft, ..magically, there is a fire event that blocks the front door egressing capability.
Now what?
By definition the loft is not another room, or a bedroom; it is part of the room or space in which the level or levels are located. Some are using emotional arguments to force people to apply codes that are not applicable. A loft is "part of a room"; not a room. You can have a loft in your bedroom if the ceiling is high enough.Uncle Bob said:I think Mark has the right idea with this picture. "2009 IRC, definitions. Mezzanine, Loft. An intermediate level or levels between the floor and ceiling of any story with an aggregate floor area of not more than one-third of the area of the room or space in which the level or levels, are located." It is NOT a bedroom and does not require separate emergency egress. Uncle Bob
The only place that I can find mezzanine or loft in the IRC is the definition that Mark posted. The only obvious reason for the definition is to limit the size of a mezzanine or loft.Uncle Bob said:I think Mark has the right idea with this picture. "2009 IRC, definitions. Mezzanine, Loft. An intermediate level or levels between the floor and ceiling of any story with an aggregate floor area of not more than one-third of the area of the room or space in which the level or levels, are located." It is NOT a bedroom and does not require separate emergency egress. Uncle Bob
I see bedrooms with with a raised bed.cda said:Lets play loft or bedroomloft or bedroom
http://www.thetinylife.com/wp-content/uploads/2010/12/loft-bed-full-sized.jpg
loft or bedroom
http://crosscreekcabinsv.com/loft%20bed.JPG
loft or bedroom
http://ccithaca.com/images/gallery/12Loft-Room.jpg
It's usually measured by the square foot.cda said:An intermediate level is floor spaceis there a minimum size for it to be classified as floor space
