Electric Panel Behind Door
fj80
Sawhorse
Virginia
Is an electric panel allowed to be located behind a door (when the door is in the open position)? There would be adequate clear working space in front of the panel when the door is in the closed position.
l would say, it depends, nothing prohibits it but Article 110.26 does say that the work space shall be clear at all times.
In reality, it is better than having junk or shelving in front of it.....
I see nothing wrong with the panel being installed behind a door as long as there is access to the panel that meets the working clearances and the panel door is allowed to open 90°. With no plumbing above or below and no potential damage to the panel from the door.
Is the question due to the door hiding the panel?
No mention made as to capacity of the panel, how big the room is and whether the door swings away from or over the panel.
