I don't feel put out at all. I guess it is hard to convey expressions via typed text, but I am more than grateful and appreciative for the feedback on this forum, and appreciate all the questions.globe trekker said:righter101,Thanks for coming here to ask for assistance. I too do it all the time! Please do
not feel put off by our inquiries and interpretations. We are on the outside
looking in trying to assist you as best as we can. Please allow us to try and
work through this with you, ...we're curious too!
Looking forward to more info & pics., and a final outcome. By you telling us
how things worked out, it helps to educate others on here.
In your OP you state, "The property has an 800A service (green box). At that service, the electrician installed 4 200A disconnects." Is the 'green box' a CT cabinet with a meter and the 4 disco's mounted next to it? And is all this equipment mounted to the structure? This info will determine whether this install falls under 225 or 230.righter101 said:Im even more confused now. I re read the section in the NEC referenced by the WAC and that deals with the requirements for more than one building.I will try to get more clarification or see if there are additional amendments to the NEC, by the state.
You seem to be saying that the group of 4 disconnects is 80' away from the house. If so, they don't count as a disconnect for the structure.righter101 said:Attached are some pics of the disconnect panel, near the transformer (green box). This is about 80 feet away from the structure.
