elevator opening in a 2hr FRR firewall
bso
Member
has anyone come across a situation as the title suggests? elevator door, for highrise for instance, typically comes with a fire separation of 2hr FRR. but can it be located in a firewall? there are a whole bunch of additional requirements such as smoke migration, and i cannot get an answer out of a the elvator guys. and there is no room to either side to add a vestibule.
cheers
I don't think it is possible unless another door is provided over the opening, since elevator doors cannot pass the smoke control requirements for opening protectives.
Another option is to make the side and back walls of the elevator shaft part of the fire wall and not use the wall with the openings. These walls probably extend above the roof anyway for the overrun or machine room, so why not take advantage of that?
bso,
Welcome to The Building Codes Forum! :cool:
TO ANY MODERATOR: Please remove the above post as it is Spam!
Welcome
Is this real life or just a question??
If real life, why is the 2 hr wall there??
welcome. Is this a fire barrier, fire wall, or what? Is it a horizontal exit? It makes a difference for when smoke resistance is required.
Ok sounds like the shaft is two hour, but why is the other two hour rated wall there???
The traditional application for an elevator is not to penetrate a fire wall..... I hope the original poster is correct in that this is a true fire wall and not a fire barrier or fire partition.
bso - Can the elevator face the other way and use the existing firewall as an hortizontal exit?
