Emergency window and well issue
SCBO1
MID WEST
I recently did a final inspection on a two family home where the lower basement had an EEO with window well. While inspecting the main floor bedroom the EEO TWIN window was placed partly over the basement well EEO window. Depending on which of the twin window openings you use, you could land in the well when trying to exit.
Any suggestions other than moving the bedroom window, would half an EEO be permitted? Can an EEO window be placed over another EEO or EEO well?
With steveray on this one, it could be a second story, over a walkout basement and with a area well...............buyer beware!o_Oo_O
Interesting
Any grate over the basement well at ground level??
Requested one, was told they were going to install a piece of hinged Lexan? The stuff the "Red Wings" slam the "Islanders" up against at the rink! Not installed yet.
  • Like
Reactions: JBI
The other thing is if you have a two story house on a hillside and you open the second floor bedroom window
Besides the two story drop, there is the extra fifty feet to the canyon floor.
Which most ahj's do not regulate
JBI,
meant to say when the "Islanders" slam the "Red Wings" against the glass. I better not bring those "Penguins" into this thread.
  • Like
Reactions: JBI
As long as the window opening is more than 24" above the finished floor there is no code violation
R312.2.1 Window sills.
In dwelling units, where the opening of an operable window is located more than 72 inches (1829 mm) above the finished grade or surface below, the lowest part of the clear opening of the window shall be a minimum of 24 inches (610 mm) above the fininshed floor of the room in which the window is located....
Might install a removable fiberglass grating over the window well??
According to me, I will gusset you that you should EEO window be placed over another EEO or EEO well.
