indyarchyguy
I have a project that involves an existing building (school). The building is an existing, non-sprinklered building with 1-hour corridors. The doors leading to the classrooms are solid-wood core doors that are not labeled, nor are the frames. There is a wood transom above each door. There is no door frame header between the top of the door and the wood transom. My client wants to replace the doors with 20-min rated doors. My interpretation is that if you replace the door, then you have modified the assembly and therefore would need to replace the door frames and transom to correct the assembly. The Owner's rep is arguing back that if you only replace the door, then you haven't modified the assembly so you wouldn't have to replace the frame and transom. This is in a jurisdiction using amended 2015 IBC. Thoughts?
