Good afternoon all
Code is 2009 IBC. I have an M occupancy with a mezzanine, occupant load is 8 persons. This is served by a single enclosed stair, with a door at the bottom of the stair well leading to the exterior exit discharge. The stair is both the entrance to, and the exit from, the mezzanine. The question is whether the stair is an exit, or an exit access component, because it is also the entrance. The AHJ has expressed the view that that the clauses in 1020 saying that exits cannot be used for any purpose other than exiting mean that exits can't also be entrances. If so, I would have to call the stair an exit access component, the exit would be the door at the bottom of the stair well, and I would have to measure the 75' maximum travel distance required by 1021.2 to the bottom door, not to the door at the top of the stair. This would substantially restrict the possible area of the mezzanine. The 2009 IBC Commentary for 1020.1, however, says that the intent is to keep storage, furniture and work spaces out of exits, not to to prevent exits from being used for other circulation purposes than exiting. As I read the commentary, provided the door/stair/stairwell complies with all the requirements for exits, the door at the top of the stair could be an exit door, and I could measure the 75' travel distance from this door, and have a larger mezzanine.
How would you deal with this?
Thanks
Thanks
