Michael.L
I'm not sure what you're asking. Water hammer arrestors do not have check valves.Wouldn't this include a check valve?
It doesn't matter how many check valves or shut off valves you have downstream of your water heater (technically, everything downstream of your water heater is a closed system when all the faucets, spigots, showers, etc, are off).
The expansion tank MUST ALWAYS be connected by a permanently open pipe to the water heater tank: NO check valve or shut off valve should be placed in the piping between the expansion tank and the water heater tank. The expansion tank is placed on the cold supply side of the water heater so that the tank bladder is not subjected to high temperatures from the hot water, but pressure-wise, the hot side and cold side are at the same pressure.
You can have as many shut off valves and check valves as you want on the water piping (cold or hot) upstream or downstream of the water heater as long as NO valve exists between the expansion tank and the water heater tank. The purpose of the expansion tank is solely to absorb the additional water volume created by thermal expansion within the hot water heater as it heats cold water. Without the expansion tank, that increase in volume due to the water heating has nowhere to go, and since liquids are essentially incompressible, it builds pressure inside the tank. At best, the pressure will cause your T&P safety valve to pop-off to relieve the pressure (but realize that even when the T&P opens, the stress of repeated cycles of 150 psi pressure WILL weaken the tank and cause it to fail prematurely). At worst, you could have a catastrophic water heater tank explosion.
