pwood
when exactly are expansion tanks required on water heaters? type of fuel,capacity, closed system?
These actually do not so they "say" no expansion tank is needed. Common sense took hold and said in my opinion you need one.DanB said:The pressure reducing valves I've worked did function as check valves also. I would always require an expansion tank in the system if present.
