Fan / Light Combo in Shower Stall
Even if it is listed for "in the Shower", it will not last
long........Most light \ fan combos are manufactured
for a short life-span.
The manufacturer's have figured it out !......Designed
in obsolescence !.........Just keep on consuming ! :mad:
"UL Listed for use over tub or shower with a GFCI circuit; that means you can control ventilation by locating your fan exactly where you need it the most"
I am a true believer when it comes to keeping a bathroom as dry as possible. If a fan is in a shower stall, it will be pulling lots of moisture out of the bathroom. That's okay up to a point.....the point where the moisture condenses. The misuse of bath fans by installing long tortuous vents makes me think that these shower fans are not such a great idea. Not because of any particular danger but more due to rot.
