Fire damage assessment
beach
The SoCal Beach
Does anyone have a formula for assessing damage (dollars) after a fire for a typical home, commercial structure, etc.? We typically use the WAG method, but we were asked to come up with an actual formula......
Thanks in advance!
beach said:
Does anyone have a formula for assessing damage (dollars) after a fire for a typical home, commercial structure, etc.? We typically use the WAG method, but we were asked to come up with an actual formula......Thanks in advance!
Wild A** Guess (WAG) is the only method unless you know the current cost of material and labor.
I know many contractors that use the same method.
The problem with the WAG method is that three different WAGs vary widely, often times hugely..... The newer guys don't have any construction history...... Now they're moving up to captains and BC's. If the costs are somewhat dated, that would be better than a WAG......
I find that our line crew spokespeople are all over the place, and i don't know that there is a best practice. Square footage damaged, to what degree, destroyed? BVDT from the ICC would depend on the answers to those questions, and access to the the table.
we were asked to do the same thing for fire investigations
it was suggested maybe have an insurance adjuster or similar give a class
gb,
Thanks! I checked it out yesterday....I know the insurance industry uses it, how much is the program? Does it determine the valuation fairly quickly?
Its been 8 years since I've used the program, and I am unsure of the cost. It takes a bit of time to enter the data, but it will take less time if you don't use the cad features.
