Fire pump
jtom
Sawhorse
Va.
What code requires a fire pump flow switch to be installed after the control valve on a fire pump riser?I assume it is done this way for maintenance.Any code sections would be appreciated.
Ok there are a lot of valves when there is a fire pump set up
A little more detail ??
Each sprinkler riser will have one
So I cannot remember if one is needed on the discharge side or not.
Will try to look at the book later today
Do you want to restate your question
Or add or define some of the terms you use.
Did not look at the book yet
I am thinking
a. when ever the pump runs you will get a pump run condition, even without water flowing.
b. each riser will have a flow indicator, so that will tell water flow and which riser is flowing
c. standpipe may be the only one with out a flow, depending on how it is set up
Have you looked at NFPA 20, Installation of Stationary Pumps for Fire Protection?
  • Like
Reactions: JBI
I believe
Insurance Engineer
Is the resident fire pump expert
You might private mail him
Fire pump flow switch??? Most times the fire pump, if automatic starting, comes on via drop in water pressure. Perhaps explain what you have and will try to help.
